Samsung ICR18650-22E Cell Specifications
Brand:Samsung
Model:ICR18650-22E
Capacity:2200mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
1100mA Standard
4400mA Maximum
Discharging:2.75V Cutoff
440mA Standard
4400mA Maximum
Description:Teal Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://www.meircell.co.il/files/Samsung%...50-22E.pdf
Pictures:
Jorge palomares likes this post
Though a 2C charge rate is mentioned later in the datasheet, the max charge rate is technically 2200mA.
Datasheet link doesn't look like it works anymore, but found it also at: http://elemakku.hu/datasheets/Samsung%20...50-22E.pdf
Como puedo calcular el amperaje de descarga de la batería o cuál es el de esta?
