Panasonic CGR18650AF Cell Specifications
Brand:Panasonic
Model:CGR18650AF
Capacity:2050mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1365mA Standard
1365mA Maximum
Discharging:3.00V Cutoff
390mA Standard
3900mA Maximum
Description:Green Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://www.houseofbatteries.com/document...8650AF.pdf
Pictures:
