Samsung ICR18650-20F Cell Specifications
Brand:Samsung
Model:ICR18650-20F
Capacity:2000mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
1000mA Standard
--- mA Maximum
Discharging:2.75V Cutoff
400mA Standard
4000mA Maximum
Description:Blue (Light) Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://www.houseofbatteries.com/document...650-20.pdf
Pictures:
Cannot get the DS link to work, anyone manage ICR18650-20Fe to save a local copy?
EDIT: it works now, the site must have been down for maintenance...
(01-07-2018, 11:50 PM)Detritalgeo Wrote: Cannot get the DS link to work, anyone manage ICR18650-20Fe to save a local copy?
It seems to be working now. Try again?
Hi, I would like to ask you a question, i have the same model (ICR18650-20F) but the code under SDI is 19B5, the code under SDI is very important or i can ignore that code under the write DPI and buy a cell with the same model?.
P.S.
Im very sorry for my bad english.
(03-25-2018, 03:25 AM)Foxster Wrote: Hi, I would like to ask you a question, i have the same model (ICR18650-20F) but the code under SDI is 19B5, the code under SDI is very important or i can ignore that code under the write DPI and buy a cell with the same model?.
P.S.
The code under "SDI" indicates the date when the battery was made. You can try to use this tool to look it up however they don't have full information for every battery model: https://batterybro.com/pages/18650-date-...ookup-tool
P.S.
Oh i see... thank you very much for explaining me what this code means!.
