Samsung INR18650-15M Cell Specifications
TheBatteries
Administrator
Brand:Samsung
Model:INR18650-15M
Capacity:1500mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
750mA Standard
4000mA Maximum
Discharging:2.50V Cutoff
1500mA Standard
23000mA Maximum
Description:Blue (Light) Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://gamma.spb.ru/media/pdf/liion-lipolymer-lifepo4-akkumulyatory/INR18650-15M.pdf
Pictures:
Found 5 of these in a 20v DieHard Battery, good condition. 1.5Ah Battery pack with series connection, hence the 1500mAh rating on each cell.
