  • 7 Vote(s) - 4.86 Average
HBPowerwall (Official)
Thumbs Up
Here you'll find all the stuff I refer to on YouTube, inc - pics, prices, spreadsheets, diagrams.
If you find stuff here helpful please consider a gold coin or two my way via PayPal or Patreon
You can also catch up with me on Facebook (group) HBPowerwall Facebook Instagram Twitter YouTube
Business related inquiries - admin at diypowerwalls that dot thing com - Emails not directly relate to sponsorship or marketing will be ignored.
[Image: HBPowerwall.JPG]
Bilabob, tccack, zag2me And 10 others like this post
How much did/does/will your project cost...
Glad you asked - check it out here  Cool
.pdf   New HBPowerwall price list public.pdf (Size: 46.4 KB / Downloads: 44,347)
Off grid muso, WuggyBuggy, zag2me And 6 others like this post
Do you have a diagram of how it's all setup ?
Update
  • Solar is now , 23 195w Panels  15 in 3p5s and 8 in 2p4s configuration
  • 15 panels go to MPP PCM60X charge controller
  • 8 panels go to PIP4048MS
  • Removed neo Pixel to reduce light inside the shed (just glows at night)
  • Turned off the light ring in the router
  • Considering taking out the monitor
  • Ordered another inverter - you got that here first!
lordxenu, Jez O'Hare, Wado And 24 others like this post
If something is missing from this list hit me up via PM or email and I'll add it for you.
A is for Amazon referral link
B is for Banggood referral link
C is for AliExpress referral link
E is for eBay referral link
Charger / Discharger MPP Solar Inverter Battery Fuses between Inverter & Battery TP 4056 Plastic Battery Holders Cell Log 8 IMAX Charger Battery Holders New Heat Shrink LED voltage display Hydraulic Cable Lug Tool Cell Level Fuse wire Nickle Strip Spot Welders Inverter AC Power Meter 35mm² Power Cables (2 Gauge )
, Prandy71, mike And 6 others like this post
DIYPowerwall Mounting System
This is the mounting system that I came up with to hold my cells. It's both cost-effective & good looking rack mounting system. It makes maintaining and building your battery packs very simple and quick. I've provided as much info here as possible and if you'd like to donate to help pay for all the RnD monies that started this process it would mean a lot. The first one I had made the prototype cost just under $400 AUD and the next 4 costs about that again so was quite expensive to get it all started. My paypal is https://www.paypal.me/homebrewpowerwall. I have 8 left I can sell in stock and are $85 each and available to pick up from Brisbane Australia - I don't post.
Both Mark & Ivan have generously donated their CAD files below if you would like to build your own. Please also consider a donation to them for their contribution.
CAD Files
UPDATED PHOTO of the mount to try making it a little easier to read.  Click This image, then don't forget to hit the 'zoom in' button top right to make it original size
above diagram is straight from the laser cutters, differences in this V5 version is rounded corners where they COULD touch the cells and added 1mm (to that skinny bit at the top below the square bit) to allow for heat shrink to be fitted to reduce the chance of short to ground.
After months of use, I've successfully tested my mounts with 157 cells rather than 80p packs
Chris6S, Taz D'vil, nkako And 9 others like this post
Software -
MPP Solar PIP40408 (all pip inverters really) - WatchPower
MPP Solar PCM60X - MPP Tracker
Other MPP Solar - Software & Manuals
SMA - Sunny Explorer
Watch Power alternative  - Solar Patrol
Victron Energy Monitor - Windows Software BVM Reader USB drivers VE.Direct
Batrium Watchmon ToolKit - https://www.batrium.com/pages/howto-watchmon4-software-install
General Video of my software setup
Current Setup and software walkthroughs
Dave, Amitparmar, Joaquinsfy like this post
Ender3 3D printed gear
Paul Kennetts 18650 battery pack Mounts STL - http://www.thingiverse.com/thing:1729730
iCharger X6 stand STL - https://www.thingiverse.com/thing:3008778
OPUS BT-C3100 fan mod STL - https://www.thingiverse.com/thing:2267571
AZ-Tekkie's 18650 Wall mount STL  - https://www.thingiverse.com/thing:2572115
K-Weld Electrode Holders - https://secondlifestorage.com/t-Easy-to-...=electrode
Kweld housing STL - https://www.keenlab.de/index.php/product...stl-model/
Dave likes this post
Did you ever figure out a decent battery balancer? I know at one time you were looking. Those small ones appear to make a noise and was wondering if you found a better solution.
Secondly, I notice you have a 48v inverter. Does this mean you have these batteries packs in 14 series (3.7v nominal * 14 = 51. 8v) ? I'm thinking 48v is the way to go because if you need, even momentarily, 50 Amps of 120V AC, that would be over 500 Amps at 12V.
Edit:
I see you are doing 14S3P Smile
(01-02-2017, 03:06 PM)cstanley Wrote: Did you ever figure out a decent battery balancer? I know at one time you were looking. Those small ones appear to make a noise and was wondering if you found a better solution.
Edit:
No balancer yet, i'm open to sponsorship offers :Smile
edit yes i don't know how you say it is it 80p14s2p lol but 3360 cells
Dave and Govi like this post
Awesome, one thing - I haven't delved much into the solar aspect yet. Can you explain what's going on with the way you have the solar panels positive wired to the PCM60X then from the PCM to battery and fused to some input on the PIP? Can you also explain the SHUNT situation you have going on with all the negative wires? Thanks!
Users browsing this thread: 78 Guest(s)
