  • 7 Vote(s) - 4.86 Average
HBPowerwall (Official)
Solar panels > breaker > 40m cable > breaker > PCM60X > SHOULD BE A BREAKER > Positive to battery, Negative to INVERTER side of shunt. This is so energy has to go THROUGH the shunt to measure power in and out correctly. it power Comes in from PCM60X and can go directly to the inverter if I had it on the battery side of the shunt it would measure the power going through the shut on the way to the inverter hence giving the 'battery' state of charge a false reading. Does that make sense?
dglsrllr likes this post
(01-23-2017, 12:27 AM)hbpowerwall Wrote: Solar panels > breaker > 40m cable > breaker > PCM60X > SHOULD BE A BREAKER > Positive to battery
I'd be curious what breakers you're using? I really need to get some for my setup... The only ones I can find either cost $100 or don't work on DC current.
cstanley likes this post
the 100 dollar versions ...lol
this i s a test
Anyone ever wondered how many hits roll in on YouTube :Smile Would anyone be interested in seeing more of this type of stuff. As I don't mind sharing so others can learn
Hi Peter! Thanks for putting out all of the videos. One thing I may have missed or not fully understood is the arrangement of individual packs. Is one 80 cell pack, 1s80p? Then you mount those packs in series to produce 14s80p? That means you're using a 48V system and your nominal pack voltage is about 50V, correct?
Hopefully it's ok to ask about my own build here:
One thing I am looking at doing for my own build is a modular approach in which I can add capacity as I go, starting with one pack and moving forward. This system doesn't really allow that, or am I missing something? What may work better for me is 75 cell packs wired as 15s5p and mounting all finished packs in parallel. Do you foresee any problems with this?
Thanks for the clarification and keep doing what you're doing!
Yes you are correct with mine. Seems to be working for me so far. Your way sounds like it will work well. I guess it all up to you and how you want it to look, how much capacity etc. Good thing about these projects we all learn  Cool
Oi Pete,
Ever thought of adding 3 more banks to the door and 3 banks on the fixed panel holding the door in the same shed??? saves u installing another shed, and ya still got plenty of airflow. U might need to ad more supports to the hindges that suppport to the door or use a star fence picket and hammer it in flush on the on the inside of the doors fixed panel to cater for extra weight and flex.
Be ur own independant self, stop letting the ellites take ur budget.
Hi hbpowerwall,
 I watched your latest video, and the new website https://www.batrium.com sounds really fascinating. I like the name and what potential these BMS products hold for us DIYrs'.
Cya,
Paul
That's some very nice work ... very orderly and professional , and some serious storage capacity ...
The question must be , with so much capacity , what do you charge up to ? ... it seems to get the max life from the cells 3.9 or 3.8 is the highest we would want to go ??? Discharging no lower than 3V?
Users browsing this thread: Richard, 7 Guest(s)
