LG LGAAS31865 Cell Specifications
Brand:LG
Model:LGAAS31865
Capacity:2200mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1075mA Standard
2150mA Maximum
Discharging:3.00V Cutoff
430mA Standard
3225mA Maximum
Description:Blue Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
https://www.tme.eu/fr/Document/851884e7c...50-2.2.pdf
Pictures:
Seems to be the ICR18650 S3 model
mike likes this post
i found this useful for People have this Battery ,there is a test cycle 700+ as of the following Thread and a picture of each Discharge Cycle by a member here
here is the picture
https://secondlifestorage.com/image/qhyzyf
here is the thread :-
https://secondlifestorage.com/showthread.php?tid=6868
