LG LGDAS31865 Cell Specifications
(10-29-2019, 04:43 AM)Niqyek Wrote: You're absolutely right reckless -- my bad, I meant Volts
I drew this diagram of the circuit
However the batteries are all welded together
Any ideas?
I suppose at the end of the day I could just use electrical tape and tape some copper wires to the terminals of each battery...but that's not very elegant :|
Tear appart the nickel weldings and solder some copper wires (nickel strips and point welder would be the best but I assume you don't have access to that). Just make sure that you use batteries of the same type and charge them at the same voltage before assembly. I'd rather not use tape but you can give it a try if you don't have tin or soldering iron.
