Panasonic CGR18650C Cell Specifications
Brand:Panasonic
Model:CGR18650C
Capacity:2150mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1428mA Standard
--- mA Maximum
Discharging:3.00V Cutoff
408mA Standard
4080mA Maximum
Description:Blue Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://www.rosebatteries.com/pdfs/Panaso...18650C.pdf
Pictures:
Thank you Smile
Found these on a Dell battery model BATDWOOL
mike, Hannes5613, hbpowerwall like this post
seems like they're avaliable in grey too
Just tested over 100 of the blue Panasonic CGR18650C's and I noticed something which may be of interest.
My cut-off for inclusion in my project a powerwall battery bank is 1800mAh A number of these cells which were marginally below my threshold were tested again twice more. Unlike some cells which show similar or lower capacity on re-testing these on average give 100-150mAh more in subsequent tests. So cycling them appears to increase capacity more than I can say I noticed with other manufacturers.
J
