Samsung ICR18650-22P Cell Specifications
Brand:Samsung
Model:ICR18650-22P
Capacity:2150mAh Rated
Voltage:3.62V Nominal
Charging:4.20V Maximum
1075mA Standard
2150mA Maximum
Discharging:2.75V Cutoff
430mA Standard
10000mA Maximum
Description:Purple (Light) Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://www.tme.eu/de/Document/cf2b91a946....2P-HV.pdf
Pictures:
Fulstein likes this post
[attachment=387] photos as requested
if not required quality, i can send higher resolution
best regards
Stefaan
They're perfect, thank you Smile
NB from the ICR18650-22P datasheet listed above, these cells are rated to 10A continuous discharge.
I don't really know why maximum discharge is specified as 4875mA on this page.  You have been warned peoples -- do NOT trust info on these pages.  Better to read the data sheets themselves, and not rely on correct transposing etc.
(05-14-2018, 10:24 PM)DCkiwi Wrote: NB from the ICR18650-22P datasheet listed above, these cells are rated to 10A continuous discharge.
Updated, thank you!
Hi there I just came across green Samsung icr18650-22hv. Any idea what the specs are?
(02-14-2019, 02:28 AM)paulz Wrote: Hi there I just came across green Samsung icr18650-22hv. Any idea what the specs are?
Its an ICR18650-22HU Didn't make a HV that I am aware of.
Cell database has that one.
mike likes this post
Hi,
I have those cells and few of them after testing shows 2600mAh. Tested with litokala lii500. Is this possible? Howerboard batteries.
(09-02-2019, 05:41 PM)a.ostojic Wrote: Hi,
There is either something wrong with your tester, testing method, or they are fake cells. Are you checking the capacity on discharge and NOT the amount it charged?
I have two testers and both have show high capacity. For example on same spot in nex round it measure 1899 which seems ok. I'm using Nor test which is discharge.
