Panasonic CGR18650DA Cell Specifications
Brand:Panasonic
Model:CGR18650DA
Capacity:2450mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1630mA Standard
--- mA Maximum
Discharging:3.00V Cutoff
466mA Standard
4660mA Maximum
Description:Purple Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://www.dipmicro.com/?datasheet=CGR18650DA.pdf
Pictures:
