Unknown ASO/SZN Cell Specifications
(02-13-2019, 11:41 PM)paulz Wrote: I just found some.. going to test on opus and treat it as a 4.35v battery. Will test one on 4.2 and then 4.35. I saw some specs that makes me believe these are LiHV cells.
I would make completely sure of this. Charging to 4.35v does not yield a huge gain in capacity, and if the cell is not LiHV it may explode.
ASO  GK2K121EP  811930  SZN
6 cells recovered from an unused ML:4710 Acer battery pack 4400mAh 49Wh (generic NON-branded)
Wrapper = Mauve/Pale Purple
Insulator = Translucent /White
All cells seem to charge to 4.2v OK and discharge to 3.00v
HI
I have ASO GI4I051EJ1 814808 (purple-white ring)
i bought them as 2600mAh high drain 20A.
These are 2000mAh rated. Do not trust what the laptop battery pack label says. I have opened up hundreds of generic packs now, and I can confidently say that 0% of them were labeled correctly; all of them were "hopelessly optomistic" and had a higher rating on their label than the cells they used inside.
Also, these ASO cells are definitely not high drain cells. I don't have a data sheet, but I wouldn't push them past 2C.
Lastly, these are very good generic cells. I'm doing a longevity test on these and you can follow my progress here: https://secondlifestorage.com/t-Generic-...y-any-good
Mike, can you change these from "Unknown" to "ASO" as the brand? I originally thought these were missing from the cell database, but they were mislabeled "Unknown."
Geek likes this post
Also found some of 12 these GE20106EW in a notebook battery. The spec on the notebook pack say its about 2200mah. The IR looks very good and i will post the cap. results later
Got a Purple wrapper with White insulator ring, Model number GG20304EG, tested at 2154mAH on 1000mAh discharge on an Opus.
Mobilis in Mobili
Cell count as of 10/10/2019
191 Cells of Everything Else
68 In progress
More info on my Google Drive
I found a few of these in laptop batteries. An initial capacity test with my Opus BT-C3100 yields roughly 2100mAh consistently.
(Ignore the handwriting at the bottom, that's my personal serial number system)
Do you have any data on these batteries 18650 2200 mAh EB17L11
Thanks,
#29
the folks that figure these are 2600mah cells from the specs are wrong.
these are 2000-2200mah new.
aftermarket pack mfrs lie about their packs capacity.
this is why many such packs are at 75-80% wear level after the first cycle.
they clone the bms data and the chip calculates the capacity compared to the design capacity.
Generic likes this post
