Samsung ICR18650-26H Cell Specifications
Brand:Samsung
Model:ICR18650-26H
Capacity:2600mAh Rated
Voltage:3.63V Nominal
Charging:4.20V Maximum
1300mA Standard
2600mA Maximum
Discharging:2.75V Cutoff
520mA Standard
5200mA Maximum
Description:Pink Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://grobotronics.com/images/companies...50-26H.pdf
Pictures:
found 2 packs, (total 12 cells) with these cells in them, every single cell when discharge tested from 4.2v to 3.2v at 1 amp all return between 2600mah - 2700mah. seems kinda weird.
(10-09-2018, 03:57 AM)nosam_xd Wrote: found 2 packs, (total 12 cells) with these cells in them, every single cell when discharge tested from 4.2v to 3.2v at 1 amp all return between 2600mah - 2700mah. seems kinda weird.
Have that to, lots of them over 2700 mAh.
Datasheet link appears to be broken. Try this one - http://grobotronics.com/images/companies/1/datasheets/ICR18650-26H.pdf?1511772798728
Also check the max charge current and discharge current, they appear to be higher according to several sources.
Might explain why capacities tend to read higher at 1a discharge.
(10-10-2018, 04:30 AM)Geek Wrote: Datasheet link appears to be broken. Try this one - http://grobotronics.com/images/companies/1/datasheets/ICR18650-26H.pdf?1511772798728
So if I use 1300mA to discharge, the mAh outcome would be correct?
If yes, does this mean that if I use 1000mA I should divide the outcome by 1.3 to get the correct capacity?
Or is it not this simple...?
Not quite. Cell capacity does read higher at lower discharge rates. Look at some of Thunderhearts graphs.
Datasheet and data updated, thank you Smile
