Samsung ICR18650-26FM Cell Specifications
Brand:Samsung
Model:ICR18650-26FM
Capacity:2600mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
1300mA Standard
2600mA Maximum
Discharging:2.75V Cutoff
520mA Standard
5200mA Maximum
Description:Pink Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
https://cdn.shopify.com/s/files/1/0674/3...1413850609
Pictures:
None. Please submit some!
Lightbulb
I found this cells in cheap Whitenergy Premium laptop battety. Well, i do not use it now in powerwall but today i am testing it. When i will be done i will post results.  Wink
OK, i tested 4 cells.
I read 2500mAh. It was tested at 1.2A and 0.6A discharging with the same results.
Tested mine and came out at 2600 - 2900, with most falling in at 2700 - 2800 mAh at 1A discharge in Opus BT-C3100 tester. I got them out of an ebike battery.
I think the"M" means medical. I only find these in medical packs and they have the same characteristics as the F model. Also, the spec sheet for these day for model F/FM
mike likes this post
i found this:
  • Country of Origin: South Korea (F) or Malaysia (FM)
what do you think? can be fm the same as f, but made in malaysia?
today i am testing this cells again with new charger so i post new results soon.
I can confirm finding these in laptop batteries. I have hundreds of them and never opened any medical-related packs.
These are pretty good -
here is a spec sheet:
https://batterybro.com/products/samsung-...00mah-5-2a
                                ( o o )
+--------------------------.oooO--(_)--Oooo.-----------------------------+
|   Howie Grapek                        South Florida, USA               |
|   cell: 303.818.9414                  email: howiegrapek@yahoo.com     |
|   phone: 561-819-9988                 http://www.howieshomestead.com   |
|                            .oooO                                       |
|                            (   )   Oooo.                               |
                               \_)    ) /
                                     (_/
Here is another spec source with more info
https://voltaplex.com/samsung-26fm-18650...18650-26fm
