BAK C18650CC Cell Specifications
Brand:BAK
Model:C18650CC
Capacity:2600mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
2600mA Standard
2600mA Maximum
Discharging:3.00V Cutoff
1300mA Standard
5200mA Maximum
Description:Gray Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
https://sep.yimg.com/ty/cdn/theshoreline...0-2600.pdf
Pictures:
Here ya go mate.
Thank you! I added the 2nd one. If you can clean a single cell out of the holders/packs like we have in the other threads, that would be great Smile
The white is a bit stained and faded ( that's why it's looks orange'ish) due to age but amazingly they still test @ 2600mah.
mike likes this post
