Panasonic NCR18650D Cell Specifications
Brand:Panasonic
Model:NCR18650D
Capacity:2900mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
1780mA Standard
--- mA Maximum
Discharging:2.50V Cutoff
0mA Standard
--- mA Maximum
Description:Gray Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
Just discovered this nice tag for "celldata". Can this be easily exported for all cells ? (Like to make a series of barcodes with)
Panasonic,NCR18650D,2900,3.70,4.20,1780,--- ,2.50,0,--- ,Gray,White,18650
Found a PDF that says 2700 mAh. It looks original at https://www.google.com/url?sa=t&source=w...VvNaFEKsLm
Regards,
Gary G.
Working on a 32 port #FCDS
24 ports complete... logging to Influx/Grafana
It's rated for 2900mAh under the standard discharge rate. The 2700mAh for a higher discharge rate and non-typical temperature.
I found some info about the cell.
https://voltaplex.com/panasonic-d-18650-...-cgr18650d
Proper spec sheet shows 2350mA for the CGR18650D I think the NCR18650D is the same.
https://voltaplex.com/media/whitepapers/..._Sheet.pdf
(02-11-2019, 06:09 PM)Wolf Wrote: Proper spec sheet shows 2350mA
That sheet is for CGR18650D, different from NCR18650D.
I know I just corrected that but I saw that they were the same I will get proof if the case.
I saw it had both model numbers on the voltaplex page, but the picture is just a grey cell with no text. Seems odd to me, not sure how reliable that site is? I did a quick search for NCR18650D PDF and found one for NCR18650, but not NCR18650D. I assume the specs are probably the same, but not sure and don't want to assume.
OK just checking as I am building my sheet with the same data and adding the Standard charging, standard discharge charge cutout mA and IR if available
Sorry to bother and don't want to miss inform anyone.
Found it you were right  but here is the NCR18650D
http://www.firstenergypower.com/product/...00mAh.html
Datasheet
.pdf   NCR18650D S3 SANYO Panasonic.pdf (Size: 135.67 KB / Downloads: 303)
