Samsung ICR18650-26A Cell Specifications
Brand:Samsung
Model:ICR18650-26A
Capacity:2600mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
1300mA Standard
2600mA Maximum
Discharging:2.75V Cutoff
520mA Standard
5200mA Maximum
Description:Pink Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://www.hobishop.lt/uploads/4/5/7/0/4...50-26a.pdf
Pictures:
