Samsung ICR18650-26D Cell Specifications
Brand:Samsung
Model:ICR18650-26D
Capacity:2600mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
1300mA Standard
--- mA Maximum
Discharging:2.75V Cutoff
520mA Standard
--- mA Maximum
Description:Pink Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
Not the greatest source but it appears these are rated at 2600mah and high discharge (e-cigs).
https://www.alibaba.com/product-detail/I...82924.html
There's a fair few other links on google that supports their 2600mah claim.
Thanks, the information has been updated.
2600mAh is rather obvious given Samsungs naming scheme Smile
However, as it is the case with most ICR batteries this isn't a high discharge /high drain /power cell. The datasheets from the other ICR18650-26x versions all state a maximum discharge of 5.2A. It is a reasonable assumption that it is the same for the D version.
Believe the ICRs are 5a (2C), and the INRs are 25a (12C) continuous and 30aA (15C)?
Believe the ICR is based on cobalt, and INR is based on nickel, giving the better pulse/continuous rates.
Since that sort of detail could determine safety of the cell, would rather see it in a datasheet before adding it. Thanks though Smile
I have a bunch of those and can not find the specs anywhere!!! how weird!
