HYB ICR18650NM Cell Specifications
Brand:HYB
Model:ICR18650NM
Capacity:--- mAh Rated
Voltage:--- V Nominal
Charging:--- V Maximum
--- mA Standard
--- mA Maximum
Discharging:--- V Cutoff
--- mA Standard
--- mA Maximum
Description:Turquoise Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
This cell can be charged at 2A/1C, which means its capacity is 2000mAh/2Ah, at a maximum voltage of 4.2V.
I found this interesting PDF about a ton of unknown cells, so I think this could help you:
https://www.google.ca/url?sa=t&rct=j&q=&...HCsj-qaPug
This downloads a PDF about a lot of cells.
mike likes this post
I also found this page which gives detailed specifications, but the cell looks different. I'm not sure if it's the same brand? It has the same logo, but am not sure what to think about the wrapper difference.
http://product.dzsc.com/product/infomati...34947.html
Huh? What are you talking about? I didnt even visit the page you linked ?. But I don't knoe if it's the same cell as you said, I only looked on that datasheet for finding the cell's properties.
(07-20-2017, 02:07 PM)BlueSwordM Wrote: Huh? What are you talking about? I didnt even visit the page you linked ?. But I don't knoe if it's the same cell as you said, I only looked on that datasheet for finding the cell's properties.
The page you linked to does not give full specifications for the cell. The page I linked to does, but the wrapper is different. I'm asking why and if it's reliable. Your page doesn't give enough information to add here.
Oh okay. I get it now I'm going to do more research on that cell then.
all list of HYB
ftp://support.danbit.dk/B/BAT3.7V4.2A-LI...20cell.pdf
