Samsung INR18650-30Q Cell Specifications
Brand:Samsung
Model:INR18650-30Q
Capacity:3000mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1500mA Standard
4000mA Maximum
Discharging:2.50V Cutoff
600mA Standard
15000mA Maximum
Description:Purple Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
https://eu.nkon.nl/sk/k/30q.pdf
https://eu.nkon.nl/sk/k/30q-specs.pdf
Pictures:
Here's the data sheet for this cell: https://eu.nkon.nl/sk/k/30q.pdf
And here's the spec sheet: https://eu.nkon.nl/sk/k/30q-specs.pdf
hbpowerwall and mike like this post
