Panasonic CGR18650 Cell Specifications
Brand:Panasonic
Model:CGR18650
Capacity:1400mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
910mA Standard
--- mA Maximum
Discharging:3.00V Cutoff
260mA Standard
1560mA Maximum
Description:Pink Cell Wrapper
Black Insulator Ring
18650 Form Factor
Data References:
http://www.206xs.com/topics/battery/iontd2e.pdf
Pictures:
Having never read a spec sheet before is this saying that to get optimal mAh you need to discharge at about 260 mA?
Would discharging at higher currents dramatically decrease the capacity?
I ask because I have a ton of these testing rather low but I'm discharging at around 500Ma.
(07-22-2017, 05:55 AM)Daggerzz Wrote: Having never read a spec sheet before is this saying that to get optimal mAh you need to discharge at about 260 mA?
Having cataloged so many cells, it seems when these companies test cells they test at 0.2C to get the "standard discharge rate" and capacity. I don't think testing at 500mA would give a substantial difference, if there even is a difference at all. If you pull up the spec sheet, there is a graph showing capacity over various discharge rates.
