Samsung ICR18650-26J Cell Specifications
Brand:Samsung
Model:ICR18650-26J
Capacity:2600mAh Rated
Voltage:3.63V Nominal
Charging:4.20V Maximum
1300mA Standard
2600mA Maximum
Discharging:2.75V Cutoff
520mA Standard
5200mA Maximum
Description:Pink Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://www.hurt.com.pl/prods/bat/_li_ion/ICR18650-26J
http://www.thefalconboard.com/samsung-data-sheet.pdf
Pictures:
