  • 1 Vote(s) - 3 Average
Busbars, styles - designs - success - failures
So the whole busbar design is evolving slowly with Jehu's design as one of the earlier solder jobs so to speak.
Altho there were many others feel free to add to this list  I would like to compile all the different types of busbar designs mine as we all know were well based on Jehu's design one busbars between two cells with a fuse on the positive end and regular copper wire on the negative end. Link below has a list of parts he used.
https://youtu.be/raBWFsPlx7w
List of parts used to make this project:
Laptop Batteries http://j35.us/Ebay-Laptop-Battery-Lot
18650 Holders http://j35.us/18650-spacer-clips
Copper buss bars http://j35.us/1NGpBo4
Brass strips http://j35.us/Small-Brass-Strips
Cell Fuse wire http://j35.us/1k-Ohm-resistor
Nickel strips http://j35.us/1PRIreE
My version is below and even that has evolved some what.
Then there is Mike who released his first video the other day with his process.
Or even no busbars
15 seconds of fame did soldered nickle strip
Damian Rene - does epic packs, however more E-Bike related. Spot welded Nickle Strip
Link to whole channel rather than a specific one definitely up there with Jehu's videos when I first started.
https://www.youtube.com/user/DamianBSS/videos
Then - THEN there is what I consider the current standard
UK DIY Powerwall - one of the earliest running setups I've seen even before mine !
This list will grow as I get time but any newbies out there - above video is how to do it in my opinion !
Feel free to add to this list links or photos of your busbar designs it'll definitely help others moving forward with these projects..
AND Make sure it's not just the good.. you learn faster from mistakes in my opinion
Design flaw using copper to bind the busbars together was the issue with Rohan's packs. Simply fixed by using zipties.
Here's my style of bus bars.  Copper is 12awg and has been working perfectly.  Been in production now for 3 months with no problems.
hbpowerwall and Solexx X like this post
Off Grid Setup
3 - 320watt 24v Panels - MPPSolar 2424LV-MSX - 672 Cell 96p7s 5.5kw Power Wall
Retired pack 2kw 420 Cell
On Grid Setup
44 - 250 Watt Panels with Enphase micro inverters
Glubux's amazing project http://secondlifestorage.com/t-Glubux-s-Powerwall
Glubux likes this post
Nicks Powerwall idea with four cells deep - making great use of the single cell holders that's for sure.
[Image: NicBrdo%e2%80%8e.jpg]
Daniel Barbu likes this post
Paul Boxer's design - looks pretty neat!
[Image: attachment.php?aid=139]
mike likes this post
Vladislav Haltof version (mounts available from thingspace I think)
2* 10S24P (36V) = 4kWh ready. This two sets are connecter parallely to easy balancing
João Luis Martins, version of busbars
Hi!
I probably missed something about the busbar material. Is there a specific reason why most of you do not use the nickelstrips on a roll as busbars?
I learned it good because of the low internal resistance, but isn't corrosion an issue with the copper wires? Did i miss something concerning Amperage?
If thats the wrong place to ask .. i'll move the question .
Many thanks and best,
Christian
(04-30-2017, 05:34 PM)crud Wrote: Hi!
Christian
Most are fusing each individual cell with a Tesla style fuse. If you use nickel strip you can't fuse them individually. That's one reason. Another is that true nickel strip is expensive. I hope that helps.
Alec
hbpowerwall likes this post
Hi Alec,
thanks for the reply! Concerning the nickel strip, i actually wasn't thinking about attaching them directly on top of the cells like in the spotwelded versions but rather as a real busbar in between the cells and using that as the main bus and still solder the fuses to it. Do you think this may be a wrong appliance of the nickel strip? I see the width of the nickel strip might be an issue, too. Concerning the pricing, i see the point. I was really wondering if there is a main electrical disadvantage concerning amps or else.
Best,
Chris
100 User(s) read this thread:
hbpowerwall (12-09-2018, 09:35 AM), daromer (12-09-2018, 04:18 PM), Minatugar (04-30-2017, 08:47 PM), Sean (12-09-2018, 01:48 AM), mike (12-09-2018, 01:01 AM), AveRageJoe (07-01-2017, 08:25 AM), station240 (10-28-2018, 07:03 PM), PaulKennett (04-04-2018, 02:25 PM), Joaquinsfy (12-08-2017, 10:36 PM), Majorphill (10-17-2018, 11:56 PM), coolfx (08-05-2017, 10:27 AM), ruby2 (12-08-2017, 02:21 AM), Korishan (12-09-2018, 03:58 AM), A + A (08-23-2017, 02:21 PM), P.Tasyo Powerwall (10-17-2018, 04:40 PM), PAF (10-17-2018, 01:22 PM), Prahe86 (05-16-2017, 02:46 AM), Daniel Barbu (02-18-2017, 12:58 PM), Darmok (05-02-2017, 01:15 PM), Wattsup (07-21-2017, 11:53 AM), Scepterr (05-23-2017, 05:55 AM), eeesOap (02-19-2017, 03:40 PM), Elmo (02-20-2017, 10:07 AM), Project (04-30-2017, 09:57 PM), Batteriapan (05-01-2017, 07:51 PM), skyfridge (03-11-2017, 05:06 AM), CrankyCoder (03-31-2017, 05:10 PM), Alec_J (04-30-2017, 07:49 PM), Mike C (10-29-2018, 08:59 PM), Droid126 (05-27-2017, 03:37 PM), eAnic (06-09-2017, 09:13 AM), C11MAN (05-01-2017, 07:11 PM), jdeadman (10-29-2018, 12:59 AM), crud (09-11-2019, 12:53 PM), wim (10-17-2018, 04:53 PM), hugo5464 (04-09-2017, 03:59 PM), coconut2k13 (09-02-2017, 09:52 AM), MajStealth (05-01-2017, 12:40 PM), frnandu (05-17-2018, 12:28 PM), typ49 (05-22-2017, 09:12 AM), VicRC (05-17-2017, 11:05 PM), KD0CAC (04-30-2017, 08:15 PM), 1958 greyhound (07-19-2017, 10:50 AM), Abarth595 (10-09-2017, 01:22 PM), kktuo (07-22-2017, 11:38 AM), rebelrider.mike (07-23-2017, 07:36 PM), watts-on (12-09-2018, 09:34 AM), Dan Lim (06-06-2017, 04:23 AM), jesusangel (12-09-2018, 08:48 AM), Hanssing (12-08-2018, 11:51 AM), HyTech (07-26-2017, 02:57 AM), autobd (08-26-2017, 11:47 AM), tamkov (12-09-2017, 07:43 PM), quake101 (12-07-2017, 12:04 PM), Joost2 (08-17-2017, 07:43 AM), ismaildoganw (07-18-2017, 08:46 AM), kazbach (07-31-2017, 01:06 AM), Stefaan De Ridder (12-09-2018, 01:11 PM), AzJames (07-24-2017, 04:35 AM), TomTinkerDIY (07-17-2017, 08:36 PM), Chiptosser (12-09-2018, 02:59 AM), systemtm (09-09-2017, 08:06 PM), Inverted 18650 (08-23-2017, 03:50 AM), josephchrzempiec (12-07-2017, 07:23 AM), BlueSwordM (12-09-2018, 03:37 AM), Dennis Van Hoek (07-10-2017, 11:20 AM), Happy Camper Homesteader (07-17-2017, 08:04 PM), Eric Koshinsky (08-09-2017, 03:55 AM), colishere (08-24-2017, 05:48 AM), Shade (08-01-2017, 08:18 PM), Robert Crawley (08-08-2017, 06:37 AM), Pyro (08-01-2017, 11:01 PM), Mazlem (12-19-2018, 09:02 PM), ivnz (12-10-2018, 12:18 AM), Geek (12-10-2018, 12:38 AM), 45T-XR (08-16-2017, 06:39 AM), Kenneth Bonanno (09-21-2017, 09:00 PM), Jon (10-29-2018, 02:07 AM), Steve Kopesky (08-24-2017, 10:30 PM), Olberg (12-28-2017, 04:12 PM), mr_hypno (01-29-2018, 09:33 PM), jgalton (08-25-2017, 07:14 PM), floydR (12-09-2018, 06:29 AM), esurigao (12-07-2017, 07:46 AM), Matthew Nagy (01-30-2018, 08:11 PM), higher_wire (06-22-2018, 01:08 AM), zombielinux (09-01-2017, 01:27 AM), Chris Jardine (05-30-2019, 11:04 AM), osweld (09-14-2017, 03:32 AM), zag2me (09-26-2017, 11:21 AM), emerca (12-10-2018, 11:59 PM), ChrisD5710 (10-29-2018, 11:22 AM), cristof (12-07-2017, 09:08 AM), accoelho (10-26-2017, 03:20 PM), Jespek (12-13-2017, 08:20 PM), rev0 (05-07-2018, 01:43 AM), revolting (10-30-2017, 05:22 PM), not2bme (12-10-2017, 06:31 AM), paz45 (12-07-2017, 02:51 PM), ad8mustanggt (04-04-2018, 06:15 PM)
