LG LGDA2E18650 Cell Specifications
Brand:LG
Model:LGDA2E18650
Capacity:2250mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
1000mA Standard
--- mA Maximum
Discharging:3.00V Cutoff
500mA Standard
--- mA Maximum
Description:Grey Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
(08-14-2017, 02:23 PM)mike Wrote: Warning: The information in this thread was obtained from various sources on the Internet, including any datasheets linked below, and is provided for reference only. It is not guaranteed to be accurate. To prevent fire or personal injury, never charge or discharge a cell before verifying the information yourself using the original specifications sheet provided by the manufacturer.
Brand:LG
Model:LGDA2E18650
1000mA Standard
--- mA Maximum
500mA Standard
--- mA Maximum
18650 Form Factor
Data References:
Pictures:
http://bbs.mydigit.cn/simple/?t521353.html lists the cells at 2600 mAH
I have 6 from a battery pack tested over 2300 each.
MissSolar likes this post
