  • 2 Vote(s) - 3 Average
Various Flashlights And Things Get 18650ed
I changed the title here, as I'm adding more flashlights to the thread that I've 18650ed, rather than start a new thread for each one. Smile
Here is the vintage headlamp I did to start with:
Ok, the headlamp may or may not be vintage, but it certainly looks vintage. It's one of those headlamps with the power cord that runs down to a belt pack. It worked ok as it was, but it takes 6 D cells to run a dim little bulb. I've been wanting to upgrade this thing since before I knew about 18650s. So here it goes.
I found that 4 cells fit just about perfect if they're wrapped in some pipe insulation. I also want to keep modification to a minimum so that the lamp could be restored to its original function if such a thing were to be desired.
A while back, I replaced the incandescent lamp for an LED. I don't remember the details now, but it runs on something like 3-4V.
The original power cable is in good condition, so I've left that alone. For the battery, I picked out 4 cells of the same brand and roughly the same capacity. I put an extra wire on each end so I can add a TP4056 board. That way it can be charged via USB without being removed from the case.
The lid has a small junction box, so it was fairly easy (although crowded) to connect the battery to the power cable.
Since I bypassed the original switch, I added one inside the box. I used hot glue to keep things in place, and to coat a few exposed bits to prevent shorts. There's even enough room left to hide a USB cable.
Still needs a new elastic head band, but I did put a piece of leather on the forehead part for some added comfort.
Still looks all vintagy and original on the outside. Lighter now than if it had 6 D cells in it, and USB rechargeable. The battery has something like 6Ah and the bulb draws around 0.32A. So if I've done my math right, I should get about 18 hours of use per charge.
wim, Korishan, BlueSwordM And 1 others like this post
-Mike G
Very nice! Cool
Quite nice for a small project.
Always liked that old gear well done...
cool vintage stuff
That's a cool project. More ideas for me to think about.
What were the connectors that you used for the cells? I'm sure I've seen something like that, but can't remember where.
I'm afraid I'm not allowed to talk about the particular connectors I'm using under threat of banishment. LOL
But, if you Google "18650 solderless connectors" you'll find it pretty quick.
-Mike G
Lol too funny
Yeah. I know what these type of connectors are, and where they are from. Why did you mention a ban from the sky BTW?
because he got them for free for a testing purpose or he was one of the first 'guinea pigs' Tongue
BlueSwordM likes this post
