Samsung ICR18650-26FU Cell Specifications
Brand:Samsung
Model:ICR18650-26FU
Capacity:2600mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
1300mA Standard
2600mA Maximum
Discharging:2.75V Cutoff
520mA Standard
5200mA Maximum
Description:Pink Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://gamma.spb.ru/media/pdf/liion-lipo...50-26F.pdf
Pictures:
HIGH CAPACITY!! 3400mAh Panasonic 18650 Cells, Only $1.25/ea!
The datasheet is for the -26F version, is the -26FU the same? I could find out much about the -26FU, there is no seperate datasheet I could find and you only see them very rarely while the -26F is a very common cell.
