Sony US17670 Cell Specifications
Disclaimer: The information in this thread was obtained using the specifications sheets linked below and is available for reference only. It is not guaranteed to be accurate. To prevent fire or personal injury, never charge or discharge a cell before verifying the information yourself using the original specifications sheet provided by the manufacturer.
Oh No! This cell exists in our database, but we do not have any data or datasheets on it yet! If you have any information on it, please let us know here and we will get it added as soon as possible. This database is only possible with contributions from members like you.
[Image: sonyus17670.jpg]
Brand:Sony
Model:US17670
Capacity:--- mAh Rated
Voltage:--- V Nominal
Charging:--- V Maximum
--- mA Standard
--- mA Maximum
Discharging:--- V Cutoff
--- mA Standard
--- mA Maximum
Description:Blue (Dark) Cell Wrapper
Tan Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
None. Please submit some!
I searched and couldn't find any information on them. Based on personal experience though, they are very old. I wouldn't expect more than 1500mAh from them, maybe even less.
@mike Thanks. Does they have same voltage as 18650 ? Eg, can I test them with an Opus or it is too dangerous ? (for example non powerwall usage?).
(08-25-2017, 07:36 AM)kiwi Wrote: @mike Thanks. Does they have same voltage as 18650 ? Eg, can I test them with an Opus or it is too dangerous ? (for example non powerwall usage?).
I would probably try it if it were me, but I'm not comfortable suggesting someone else try it and risking they get hurt. If you do a bit of googling, you'll find cells with a similar (but not exactly the same) model number.
Information
Found some data on these buried in a .pdf from Sony dated June 2001.
Seems they come in three flavors:
US17670G3 - 3.7v @ 1500mAh
US17670G3D - 3.7v @ 1450mAh
US17670G4D - 3.7v @ 1550mAh
The dimensions on these are 17mm x 67mm.
They will not fit in a standard 18650 holder, as they are slightly longer and thinner.
I came across these from and old laptop (Toshiba?) battery.
I would love to submit the datasheet, but I am having trouble (new member.)
Can't upload information to link provided in 1st post due to new account.
Also can't add URL in first post, but PDF file attached to this message.
Will post URL in next message.
Look at page 8-9, not to much but some specifications of US17670G3/3D/4D
This PDF also added to this message.
Best regards.
Here it is - SONY CATALOG 2001 ION ENERGY
.pdf   17670.pdf (Size: 849.81 KB / Downloads: 931)
