08-30-2017, 02:19 PM
Data References:
http://www.batteryspace.com/prod-specs/5702_5.pdf
Pictures:
Brand: | LG |
Model: | LGDBC21865 (ICR18650C2) |
Capacity: | 2800mAh Rated |
Voltage: | 3.72V Nominal |
Charging: | 4.30V Maximum 540mA Standard 2700mA Maximum |
Discharging: | 3.00V Cutoff 540mA Standard 5400mA Maximum |
Description: | Orange Cell Wrapper White Insulator Ring 18650 Form Factor |
Data References:
Pictures:
!!BLACK FRIDAY SPECIAL!!
Brand NEW LG 18650 Cells 2600mAh, Only $0.75 Each!!
^ Use discount code "BATTERY" for an additional 10% off!
