LG LGDBC21865 Cell Specifications
Brand:LG
Model:LGDBC21865 (ICR18650C2)
Capacity:2800mAh Rated
Voltage:3.72V Nominal
Charging:4.30V Maximum
540mA Standard
2700mA Maximum
Discharging:3.00V Cutoff
540mA Standard
5400mA Maximum
Description:Orange Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://www.batteryspace.com/prod-specs/5702_5.pdf
Pictures:
HIGH CAPACITY!! 3400mAh Panasonic 18650 Cells, Only $1.25/ea!
I think there may be 2 entries for the same cell, just made in different factories.
https://secondlifestorage.com/t-LG-LGDBC...ifications
https://secondlifestorage.com/t-LG-LGABC...ifications
From memory I read elsewhere on this site, that the "DB" and "AB" part of the name indicates where the cell is made, and the "C2" part is the model number.
Also on both listings is the same "Data References" link
The "Standard Charging" current is listed as being different on each listing.
From the linked PDF, I think (1350mA) is correct.
