Samsung ICR18650-24A Cell Specifications
Brand:Samsung
Model:ICR18650-24A
Capacity:2400mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
1200mA Standard
2400mA Maximum
Discharging:2.75V Cutoff
480mA Standard
4800mA Maximum
Description:Blue (Dark) Cell Wrapper
Blue Insulator Ring
18650 Form Factor
Data References:
http://www.meircell.co.il/files/Samsung%...50-24A.pdf
http://www.houseofbatteries.com/document...650-24.pdf
Pictures:
