Sony US18650GR (G8) Cell Specifications
Brand:Sony
Model:US18650GR (G8)
Capacity:2600mAh Rated
Voltage:3.70V Nominal
Charging:4.20V Maximum
1000mA Standard
--- mA Maximum
Discharging:2.75V Cutoff
520mA Standard
--- mA Maximum
Description:Green Cell Wrapper
Black Insulator Ring
18650 Form Factor
Data References:
None. Please submit one!
Pictures:
US18650DR G8 photos
A warning for anyone that comes across these cells.
I have tested many of them from various different manufactured laptop packs from a range of different years but the result is alays the same.  On the initial capacity test cycle they are showing nice # in the 1900+ range but on each capacity test cycle after that they drop by 100-200+ mAh per cycle.  I cant see these being suitable for a power wall project.
I have only done up to 4 test cycles so I cant confirm whether or not the capacity reaches 0 mAh after 10-20 cycles or if it levels out at some point.
I pulled these out of a 2s3p HP HSTNN-OB41 pack that was rated 55 Wh at 7.2V nominal.
That indicates only 2.18Ah per cell at the 8.4V max, I am not sure the 2.6Ah rating is true..
Got 8 liberated recently, all tested over 2400mAh on 1A discharge. Will try a few cycles to check for the reported capacity loss and report back.
OK, so I tested 3 cells a second time and while all of them had reduced capacity, it was just 20-30mAh less, believe it was due to a bit colder room temperature. So I guess my G8s seem to be working fine...
I have only charge current for all sony li-ion cells:
http://www.produktinfo.conrad.com/datenb...__5ER_.pdf
