Dear DIYers,...
I have a someskill in a lot of topics but not one deep enough that's DIYfor me.
I have been playing around a lot with the idea, possibilities and since i'm moving in a few months i'd like to start making things more concrete.
As money might be an issue for now, and i need to get familiar with the deep skills i would like to start small and expand later on. However i would like to start off with a 14s system. Not to waste exess money on upgrading later on. For a starter it would be overkill but i'm fairly certain it would pay off in the end and i believe in the idea
So i might start of simple, enough to led-light my shed and slowly expand. This withoutthe hassle of reconfiguring and so on made me think about the topic.
Please don't make the topic about my epic mspaint skills, they are not the topic but it is the fastest i could do. But it might help a little explaining my typed explaination.
my idea is about the expandibility more than rahter my mcgyver skills which i think are awfull. I see most people follow the same proven concept but i'd like to think diffferent.
So i was thinking about milling out slots for 14 rows wide enough for the 18650 to fit, insidemill a clear opening for the fuse wire to fit trough. afterwards i would be able to slide the cells in. But even with one block i would have a 14s configuration 'well if connected the right way at least).
Later on I would be able make another pack and with some rewiring the capacity would have expanded, and all let's say what now are called "packs" expanded evenly. But without mayor hardware changes, if assumed cabling used for let's say 10 packs this could be done with only losening the cabling on the expansion side and extending the bus bars made of heave copper plating. I have the luck I can get my hands on shorter lenghths reasonable copper wire for free.
I would place the "rows" of cells upward with some air gap to provide some ambient cooling. I am also able to "buy" the 18650 cells with my company so they become "less expensive" being "new" ones.
For now the idea is to learn from and use it as an offgrid solution.
Of course the would also be a batrium, any things i might overlook in this configuration might be welcome before i start investing money.
Thanks in advance and may the power flow greatly for you!
Bert
In case you wonder,I would use wood since it is the most basic element i can work with pretty handy And IF it were to catch fire I don't think it matters but freely correct me if i'm wrong, more minds make more ideas.
Also i made a mistake in the bank top view picture, the pos should be on the top right.
