Would you like to see additional chemistry support in the cell counter? If so, please specify which chemistries specifically you would be looking for. Thanks!
I think that if you go beyond basic chemistry groups then you will end up with a very very long list of variations / manufacturers quoting slightly different cell voltages (like Boston) that may be just aditive based variations or plate sizes for custom applications (long float low cyclic high discharge).
The other variable that may be of interest is cell size / type which is mainly for Lithium variants :
18650
21700
26650
32650
66160
Prismatic
Pouch
Lead-Acid cased
Each category also needs an "Other type" or "Other size" option... just in case...
