FST 18650-2200mAh Cell Specifications
Brand:FST
Model:18650-2200mAh
Capacity:2200mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1100mA Standard
2200mA Maximum
Discharging:2.75V Cutoff
2200mA Standard
8800mA Maximum
Description:Turquoise Cell Wrapper
Grey Insulator Ring
18650 Form Factor
Data References:
http://7087715.s21d-7.faiusrd.com/0/ABUI...1468803478
Pictures:
I believe this is the same type of cell:
FST / CJ 7G41114 30110
I still haven't figured out the naming convention for FST/CJ cells.. I think it's the first 3 in the longer serial number, 7G4 series for this cell. Tested one at 2287mAH, came from a Lenovo 6-cell 42T4643 battery.
mike likes this post
(11-28-2017, 07:18 PM)rev0 Wrote: I believe this is the same type of cell:
Thanks! Since it looks different, it still needs it's own database entry. I'll create a new entry, and link them together if it is the same. Smile
I have two cells like these, marked "18650 7K41814 35037" and "18650 7K41814 35043" above the barcode, CJ beneath it. Both came from the same laptop battery pack that my cousin tore apart.
Thanks for the info! I've been looking for a couple hours now.
I also found about 6 cells that are more similar to what rev0 found in his pack. They have the same logo but the model number scheme is totally different, and no mah or V stats included in mine unfortunately. They're also much more of a navy blue with a white insulator ring. This brand is just weird. I'll try and submit real pictures once I get them cleaned up.
i found it but does any one confirm that have tested it and it give 2200 mah or have tested it for more than 700 Cycle
