DLG N18650 Cell Specifications
Brand:DLG
Model:N18650
Capacity:2200mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1100mA Standard
2200mA Maximum
Discharging:2.75V Cutoff
440mA Standard
4400mA Maximum
Description:Blue Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://www.3apower.com/product/html/?59.html
Pictures:
Seems to be 2200 mAh according to http://suapinlaptop.vn/Cell-pin-laptop-c...00mAh.html
Manufactrurer seems to be DLG http://www.dlgbattery.cn
mike likes this post
I just found some more of these in a 9 cell 'LBI' 10.8V 71Wh laptop pack
Looks like they are made by DLG in china
Specs from this website: 3apower.com/product/html/?59
DLG 18650 2200mah 3.7v rechargeable battery cells Li-ion battery
Voltage:3.7v
Capacity:2200mah
Internal resistance;Lower than 48
Life:1000cycles
Delivery:2~6days
Grade;A
1. Nominal Capacity: 2200mAh(0.2C discharge)
2. Charging Voltage: 4.2V
3. Nominal Voltage: 3.6V
4. Charging Method: CC-CV (constant voltage with limited current)
5. Charging Current
    Standard charge: 1100mA
    Rapid charge: 2200mA
6. Charging Time
    Standard charge: 3hours
    Rapid charge: 2.5hours
7. Max. Charge Current: 2200mA
8. Max. Discharge Current: 4400mA
9. Discharge Cut-off Voltage: 2.75V
10. Cell Weight: 44.5g max
11. Cell Dimension:
      Height: 65.00mm max
      Diameter: 18.40mm max
12. Operating Temperature
      Charge: 0 to 45°C
      Discharge: -20 to 60°C
14. Storage Temperature
      1 year: -20~25°C
      3 months: -20~45°C
     1 month: -20~60°C
Wow, I think you're right. Nice work!!
Tested a few so far and results are 2470 - 2530 mAh
(discharged from 4.2V to 3.0V on 1.0A draw on B6-mini)
The text on mine is 'N18650 E09E E24D5 50991'
all the cells in the pack have consistent labels except for the 5XXXX at the end.
(12-09-2017, 04:31 AM)Detritalgeo Wrote: Tested a few so far and results are 2470 - 2530 mAh
Yeah 99% sure that last number is a sequential serial number. That's the way most of these Chinese label cells are.
I can confirm 2410-2606. How are these rated at 2200? Very confusing
Can you please post pictures of your cells?
(06-12-2018, 09:09 PM)mike Wrote: Can you please post pictures of your cells?
I can.
all above 2200mAh
I've found a green variant.  As far as I can tell they are the same cell, just a different color.  Mine all tested in the 2200mAh ballpark, but with IR in the 80mΩ range, high enough above  the makers reported as-new IR for me to believe these had an as-new capacity similar to what others have reported.  Anyone out there with a high tested capacity on these cells able to provide and IR measurement?
Mobilis in Mobili
Cell count as of 10/10/2019
191 Cells of Everything Else
68 In progress
More info on my Google Drive
