  • 2 Vote(s) - 5 Average
Cell Database Submissions and Updates
#51
UR18650AA
Datasheet: https://drive.google.com/file/d/1oRRbRVD...p=drivesdk
Sanyo AA 18650 Battery, 2150mAh, 4.3A, 3.6V, Grade
INR18650-32E
Datasheet:
https://drive.google.com/file/d/1oS3cZ6n...p=drivesdk
Official specifications (lygte-info.dk)
Typical Capacity: 3,200mAh (0.2C, 2.50V discharge)
Minimum Capacity: 3,100mAh (0.2C, 2.50V discharge)
Charging Voltage: 4.2V
Nominal Voltage: 3.65V (0.2C discharge)
Charging Method: CC-CV (constant voltage with limited current)
Charging Current Standard charge: 960mA
Charging Time Standard charge: 5hours
Max. Charge Current: 3,200mA (not for cycle life)
Max. Discharge Current: 6,400mA (for continuous discharge), 9,600mA (not for continuous discharge)
Discharge Cut-off Voltage: 2.50V
Cycle life: 500 cycles to 70% with 3200mA discharge, 300 cycles with 6200mA discharge.
Cell Weight: 50g max
Cell Dimension: Height : 65.2mm max, Diameter(max.) : Ø 18.50 mm
Operating Temperature (Cell Surface Temperature): Charge : 0 to 45°C, Discharge : -20 to 60°C
Storage Temperature: 1 year : -20~25°C, 3 months : -20~45°C, 1 month : -20~60°C
#52
Another mystery generic cell from a generic 6-cell laptop pack:
Capacity tested 584mAH/181mOhm and 558mAH/163mOhm, so not sure what the original capacity was since this must be very heavily ddegraded. I'll update if I ever find the cell info, but after a quick search of the model number(s) (FC14-HE-L097) on Google and Alibaba, no hits.
#53
Lishen LR1865EH
#54
I guess i was not allowed to add pictures to the cell database so ill post here I have some LGDDBHE21865 they are 2500mah and came from a ryobi 40v 5Ah
Note: We need pictures to create a database entry. You can upload them where it says "Drop files here to upload" in the full post editor or new thread editor.
#55
Found a cell I could not find in the database. The green one listed for ICR18650NH does not match.
Unknown brand from a laptop. Capacity rated in Wh which is unusual.
Cells tested: 4087
Average capacity: 2082 mAh
Left to process: 165 kg
#56
Haven't found these in the database, so here are some photos
1) LN INR18650
Capacity test showed 2022 (discharge with 500 mAh).
2) DSD ICR18650T
Capacity test showed 1922 (discharge with 500 mAh).
3) SZNS 18650 3,7V 7,4Wh
18650 3.7V 7.4Wh SZNS
Rated Capacity - 2000mah
Rated Voltage - 3.7V
Cut-off Discharge Voltage - 2.75V
Charge Upper Limit Voltage - 4.20±0.05V
Charging Time(Std) - 4.0hours
Standard Charging Circuit - 0.2C A
Charging Circuit - 0.5C A
Standard Discharging Circuit - 0.2C A
Fast Discharging Current - 0.5C A
Max Discharging Current - 2C A
Weight- about 50g
Height - 65mm
Capacity test showed 2185 (discharge with 500 mAh).
#57
Hi,
I have found those in a different color. Here are some pictures
Capacity test showed ~2200 (discharge with 500 mAh).
#58
Here are some more cells, that I have found in batteries for scooters. Most probably these are from some Chinese manufacturers. Battery packs were 10s2p 4-4,4Ah, so cells should be at around 2000-2200 mAh (originally).
1) HL 18650-AH00
2) ICR 18650MR
3) INR 18650HP
4) INR18650HE
Datasheet: http://www.batteryspace.com/prod-specs/6321.pdf
#59
And some more cells, that I do not see in the database
1) SZNS 18650MP
2) Sanyo UR18650AA
https://voltaplex.com/sanyo-aa-18650-battery-ur18650aa
#60
I did not find these on the database it is EVE brand and 2Ah they came from a ryobi 40v 4Ah battery
Users browsing this thread: 5 Guest(s)
