Cell Database Submissions and Updates
TheBatteries
Administrator
We have compiled an extensive database of cell information here on the forums. In order to keep improving and make it grow, we need your help! As you are breaking down your battery packs to recover cells, please consider taking pictures. We are especially looking for new cells that are not in the database yet. If you have new information to submit or update, please reply to this thread. You can new cells, pictures of cells already in the database, and spec sheets if we are missing them. A staff member will save the information to the database and put a note in the post that it has been updated.
New Cell Submissions
* New cell submissions must include a minimum of two pictures, one from the side (example picture) and one from the top showing the insulator ring (example picture). These pictures will be used to generate the thumbnail used for the database listing. These pictures must be taken directly from the front. The pictures cannot be on an angle. You may add any amount of additional pictures after the initial two. The more the better!
Picture Requirements:
* The cell must be clean. No glue, torn wrappers, capacity writing, etc.
* The picture must occupy most of the frame, not from far away.
* Please use a clean background. The cell should be the only subject in the picture. No junk in the background.
* The image should be properly lit, no dark or fuzzy pictures.
* We are only interested in high resolution pictures. Pictures should be a minimum of 2560x1960 (5MP).
* Pictures must be clear and in focus.
* Pictures must be yours that you took with your camera. Do not submit pictures from the Internet.
* Do not crop the pictures to odd proportions. Please submit the full resolution photo from the camera
Examples of Good Pictures:
Examples of Bad Pictures:
I created this new thread as a clean start. I believe I got everything from the other thread. People are starting to send in pictures from all over and I'm loosing track a bit. I updated the requirements/information in the first post. Please give it a read through before submitting any additional pictures. Thank you everyone who has contributed thus far.
The key points going forward:
* No blurry/out of focus pictures
* No cropped pictures with odd resolutions
Thank you!
I believe I have a few new cells here.
Here are some purple ASO/SZN cells. Don't know if the are the same ones as on the database already.
I have several new cells to add here (they aren't flat tops though), and one variant of a cell in the database already. I was unable to track down any information on the three new cells.
First: Interstate ICR18650 2200 (protected cell)
Unknown Brand: EL-186502200-HS :Button top
Unknown Brand: Flat top
LG Chem: ICR18650S2 (one in database is peach coloured)
Here are a couple of photos on white background for the blue wrapper 18650 6B00112 +barcode-CJ cell
This one tested to 1632 mAh on the Opus at 500ma
I found someFarasis Energy, IncIMR18650E22 cell in some Dell battery packs.
I have included the Data Sheet.
  • IMR18650E22-Farasis.pdf
TS 18650 01 3.7v 1215
6 cells recovered from a laptop pack
blue with white insulator
charged to 4.20v rested 2 hours 4.17v 1931mAh
I think there was an ebay listing for some of these cells but I'm unable to find anything more about them,
Note: Reviewed 11/20/2019, unable to find any info
Not a reclaimed cell but I thought I'd post this anyways, it's got a good price per kWH for new cells ($183/kWH for qty 200 including shipping from China, or $5/cell with free shipping on eBay in the US, as low as $4/cell for 200 qty).
Boston Power Swing 5300
Datasheet:http://liionbms.com/pdf/bostonpower/swing5300.pdf
Specs: 5300mAH
10.6A max charge rate, 13A max discharge rate, 1000 cycle life at 100% depth of discharge
Positive is the large bottom side, negative is the small circular contact. Negative can be soldered to with some sanding but positive cannot, so spot welding is required.
Here's a more complete cycle life graph:
Panasonic NCR18650PF
(Successor of theNCR18650PD)
  • Lite green heat shrink tubing
  • white insulation ring
  • black markings and warning text
  • positive and negative side marked as well
CBT18650-22J T12
Teal cell wrapper, Transparent insulator ring
6 cells recovered from a 5200mah battery for Acer UM08A71 UM08A72
Note: Reviewed 11/20/2019, couldn't find any information online.
THISS 18650 3.7V FP/18A
Green cell wrapper, Transparent insulator ring
6 cells recovered from an ACER 5920 Rating: 11.1V 5200mAh 58Wh
charged from 3.00v to 4.25v 2100mAh
Amigaman said:
LGES218650
6 cells from a genuine HP battery module HSTNN-LB42
still charging but seem to have similar characteristics as the other LG S2's in the database
Just pulled out the same from a HP pack
Sony Fukushima US17670GR batteries
Green wrapper and Black insulator ring
Sony Energytec Stg US17670GR batteries
Green wrapper and White insulator ring
New FST variant, 2600mAh according to an 8cell no-name replacement laptop battery:
Upon further research, every BLUE FST "CJ" variant I am finding on Aliexpress of this cells seems to be just 2000mAh, so I guess it was a fake capacity reading on the battery cell.
Everything about this cell is unknown, it was pulled from a Dell W1193 laptop battery.
I have not found this one in the database:
Blue, with white ring.
Label: 18650H 1 1 307 56 22S DH
Got them from a laptop: 11.1V 4400mAh
another one:
blue, with dark green/gray ring
Label: ISR18650-B 151
out of a power tool replacement 18V 3.0 Ah
Hi Mike,
These came out of an old IBM laptop pack. (IBM 02K6822)
I cant find anything on them but I'll take a guess at 2200mah and 3.7V Nominal :-D
Id also guess 2009 (from the WT081109)
I've included a shot of the base as well as it isn't flat like others...
It was in aremanufactured laptop battery. I didn't find anything about it so far.
RS 10 ZJ 18650 NMC 3,7V 20F A
15J28 A 151128 012830
The last numbers changing in this pack: 012861 or 012795
