Grumplestiltskin
Member
- Joined
- Sep 5, 2017
- Messages
- 99
I am about to embark on cell testing, and would like to hear others' thoughts on appropriate ways to test, and indeed, what to test.
I was about to purchase an Opus, but have seen other testing devices and even a few Arduino projects. While the Opus is amongst the easiest (buy it, plug it in and press some buttons) I would rather make something, even if it turns out more expensive. So long as i learn something and/or the results are more accurate, that's great.
As this is a powerwall community I figure I should be testing my cells in anticipation of use in a powerwall, and not in a portable arc welder (or some such crazy, but potentially fun, project). My cells will be subject to low stress: incomplete charge, incomplete discharge, low current draw, low current charge etc.
First, is there a consensus on some numbers related to powerwall use? E.G. max charge voltage of 4.0, or 4.1? Min (or is it max) discharge voltage?
Second, based on these limits, what is a REAL capacity going to be like? A 3200mAh cell only gets that under ideal and stressful conditions. At the reduced voltage range, what should I be expecting? I don't even want to test the maximum capacity - just interested in what each cell will do in my powerwall.
My GUESS is that if I can test under a set of conditions that more closely match the use environment of a powerwall, I should probably be happy with any cell that gets 1500+ mAh.
So - what are your thoughts on the use environment, and what is an appropriate method/device with which to test this?
Thanks in advance, Dave
