Ok. So Ive begun tearing up lots of old laptop batteries and testing the cells. I will test even the 0 volt ones as from what I have read here a few people have found good cells from the low voltage ones.
Any way my question relates to testing the cells and if I am doing something wrong.
So far I have tested over 40 cells and not found one that was high enough on capacity to use if I use the standards most of you here use. My best cell is only 1545 mah. So either Im just damnedunlucky or Im doing it all wrong.
Ive been charging the cells on a couple of imax b6ac chargers I have and Im charging the cells at .5 of an amp and then discharging them at 1 amp.
The thing that makes me think Im doing it wrong is if I take a cell Immediately its finnished discharging down to 3 volts at 1 amp I find that the cell recovers to around 3.77 volts which to me means its not properly discharged.
So tonight I retested a cell which had previously only tested at just over 450 mah but this time I discharged it at only .5 of an amp and it came out at over 1100 mah then recovered to 3.5 volt.
Now if my calculations are correct once I get my next 5 kw battery built I will have 15 kWh total capacity. The inverter in my Victron multi can draw a max of 100amps so the absolute max any of my cells should ever see load wise I think would be about .5 amp and that would be the absolute ax.
So am I testing my cells correctly or should I be testing them at a lower load.
Any advice would me much appreciated.
