Bottom balancing is a strategy for preventing an individual cell or modulein a series string from going too far over the knee into the steep part of the discharge curve, where going too low (below 2V) can quickly drivethe cell or module into reversal, which is irreversible damage. If you want to bottom balance, you have to find the State of Charge at which the first cell reaches your cutoff voltage and subsequently set your charger to the voltage of the entire pack at that point and hold it at that voltage (Constant Voltage and Float). 3.4 or 3.45Vis a good place to stop, at which you can't overecharge any cell in the series. In a Series Circuit, the current is the same through each component in the series. In Constant Voltage--and Float is Constant Voltage, too--the current will taper to what the highest cell will accept at that voltage. With Bottom Balancing, an arbitrary EMPTY has been established. Each cell or module in series is at the same state of charge(voltage)AND capacityat that point. In charging, each cell or module in series gets the same amount of current and thus has the same capacity throughout the cycle, though not necessarily the same State of Charge (voltage). The weakest cell will reach the top (cutoff voltage) first. As that cell saturates, the current will be limited by what that cell will accept at that charging voltage. The voltage of the stronger cells in the series will continue to rise. If any reaches the same voltage, they'll saturate at the same rate. Some ccells in the series might not get all the way up there, but it's okay, because they'll all have the same capacity.
Limiting the charging voltage to 3.4-3.45Vprevents damage after saturation due to heat, which begins after saturation at about 3.6V. This stratEgypt makes sense for solar, where you want to use available solar power after your battery bank is topped off, so that you can save the stored energy for when the sun isn't shining. You'll still need to monitor the cells, because shit happens, but after the initial bottom balancing the cells should stay in balance for a long time.
