BAK B18650CA Cell Specifications
Brand:BAK
Model:B18650CA
Capacity:2250mAh Rated
Voltage:3.60V Nominal
Charging:4.20V Maximum
1100mA Standard
2250mA Maximum
Discharging:2.75V Cutoff
1100mA Standard
4500mA Maximum
Description:Green (Light) Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://www.recell.ro/Files/B18650CA.pdf
Pictures:
