Sanyo UR18650ZTA Cell Specifications
Brand:Sanyo
Model:UR18650ZTA
Capacity:2900mAh Rated
Voltage:3.70V Nominal
Charging:4.35V Maximum
1450mA Standard
--- mA Maximum
Discharging:3.00V Cutoff
580mA Standard
5800mA Maximum
Description:Purple Cell Wrapper
Yellow Insulator Ring
18650 Form Factor
Data References:
https://na.industrial.panasonic.com/site...650zta.pdf
Pictures:
I'm a newbie at this. I just stared collecting cells for a couple power pack projects. I'm getting loads of old Dell 93wh packs from my IT department, and these are in most of them. Great cells so far.
The linked cell info is for a Panasonic cell, and is incorrect.
(06-07-2018, 12:43 PM)Pyromancy5 Wrote: The linked cell info is for a Panasonic cell, and is incorrect.
Panasonic owns Sanyo.
Thanks! I should just keep my mouth shut about it then.  The drawing looked more like a Panasonic button top too, but it's not drawn to scale either. it looks like Panasonic owned Sanyo until 2015.  My cells of this model are older than that.
I have several of the UR18650ZTA with white ring
And SD3A after the model No
How can buy this product
(11-11-2018, 08:12 PM)Ascanus Wrote: I have several of the UR18650ZTA with white ring
Found 4 of this.... but look a bit smaller than a normal 18650
Based in Panama
Off-Grid
PV = 3 x 200W
Bat = GEL 250Ah
Going on-grid
** 345 ** batteries harvested / getting GTILv2 2Kw auto sense 45-20V 240V
17670? perhaps ? an older cell format 17mm x 67mm
later floyd
