Toshiba LGR18650S Cell Specifications
Brand:Toshiba
Model:LGR18650S (A&TB)
Capacity:1350mAh Rated
Voltage:--- V Nominal
Charging:--- V Maximum
--- mA Standard
--- mA Maximum
Discharging:--- V Cutoff
--- mA Standard
--- mA Maximum
Description:Purple Cell Wrapper
White Insulator Ring
18650 Form Factor
Data References:
http://pdf.datasheet.live/12150411/toshi...R17500.pdf
Pictures:
The last letter denotes capacity.
Below are some I've managed to find, via google searches that returned random websites.
LGR18650P 1650mAh navy Blue cell wrapper
LGR18650R 1800mAh mid purple
LGR18650S 2000mAh light blue cell wrapper
LGR18650U 2200mAh dark purple cell wrapper
(11-21-2017, 02:38 AM)station240 Wrote: The last letter denotes capacity.
Even though the datasheet claims it's 1350mAh? Were you able to find any other datasheets?
Research on the web suggests manufacturer is: Asahi & Toshiba Battery (A&TB) Company
LGR18650R = Light purple with white ring = 1850 mAh
LGR18650P = Blue with white ring =  1650mAh
LGR18650E = clear blue with white ring= 1350 mAh
I recovered 8 'R' cells from a NEC laptop pack (OP570-73901) rated 14.4V, 3600 mAh
