Hi guys ! I just ran into a very strange issue tonight, and not sure what happened, and what will happen tomorrow when the sun will be shining (or not).
I did switch off the PIP, both battery breaker, and switch on the PIP. As I am checking the SG of my Rolls Batteries. Usually, when I switch it on, I do a check through the screen, and I can see three UI s.
Here, I did power the Beast from the battery bank, then swith ON, and almost immediately switched OFF, and reswitched ON. The screen did go on ON, OFF, and ON again in a very fast mode. I was in an unstable position, and had that unexpected movement.
The PIP produces 230VAC with no problem, there are 2 chargers : 2 MPPT, 1 on 220VAC. I tested the one on 220VAC, and it is working fine. As it is dark, night, the Winter is coming, and the night is fulll of terrors, I coudl not check the MPPTs.
Any idea on how to get back that damned UIs to be displayed on the control screen ? PIP-WhateverModel should be fine, if you have gone through such issue.
Thanks for your help.
Michel
Michel
