Hi I am Roy. I want to build a power wall that produces 8kWh @ 24v. How do I calculate the number of 18650 cells @ 2000mAh, 3.7v nominal, 4.2v fully changed? Then Ill need to figure out how to put them into packs.
All suggestions will help
Thank you
Thank you
