Hi all,
I have been running a Tesla Model S module with solar with my Outback controllers for over 5 months. I love lithium!!!!!!
Now I have seen the need to get a BMS for this setup, and adding more logic as I have found that the batteries will DIE if they are charged at 32 degrees!
I have found that someone has hacked the BMS board for this unit and I hope to be able to either use this hack, or, use my my BMS for this setup.
1) Is there an off the shelf BMS that I can use with the solar for this unit?
2) Has anyone here hacked one of these and can point me in the right direction of how not to blow myself up? I do have a couple ardruino's and I am looking at the open sourced material here -> hackaday.io/project/10098-model-s-bms-hacking
Specs of the battery ->
"They are Panasonic 18650 cells, but only Tesla has the data sheet for these. The individual cells have been verified by multiple individuals as being 3400mah. Maximum voltage is 4.2v per cell. Pack in configured 74p6s. That's 6 groups of 74 cells. Max voltage is 25.2 at 100% SOC, but it's best to only charge to 24.0v unless you monitor the individual groups, as no group should go above 4.2v."
Tesla Model S Battery Module, 24V, 250Ah, 444 Panasonic 18650 3400mAh OEM
Cheers!
Cheers!
