Important Safety Notice & User Agreement
Definitions:
You - Any person or persons accessing this website, regardless of whether you're a guest, registered member, or the usergroup your account is in.
DIY - An acronym for 'Do It Yourself' meaning any project done on your own, not planned and executed by a project contractor.
Equipment - Any tangible item relevant to a diy battery system project. This includes, but is not limited to: battery cells, inverters, chargers, wire, wire terminals and connectors, hand and power tools, cell brackets and holders, construction materials, circuit breakers, and fuses.
Agreements:
1. You acknowledge and understand that batteries, cells, chargers, inverters, electrical equipment, and any related equipment can be very dangerous, even when used in accordance with the manufacturer's specifications. Such equipment could result in fire, property damage, personal injury, or death.
2. You acknowledge and understand that any and all information posted on this website/forum is simply the experiences shared by others. It is in no way a 'how-to' guide or instructions intended for another person to follow.
3. You agree to consult and follow the manufacturer's instructions and documentation for any piece of equipment you are installing, regardless of what information is posted here.
4. You agree to consult a professional licensed electrician prior to performing any kind of electrical work whatsoever.
5. You agree to learn and follow all applicable federal, local, and otherwise, laws for your area, including, but not limited to, code and permit requirements.
6. You agree to pay for all costs associated with any personal injury or property damage that may occur as a result of YOUR project.
7. Bottom Line - You acknowledge and agree that this is a DIY (Do It Yourself) website and you are to assume any and all liability in its' entirety.
BY USING THIS WEBSITE, YOU AGREE TO ALL TERMS AND CONDITIONS SET FORTH ABOVE. YOU AGREE THAT YOU CANNOT HOLD ANY REGISTERED MEMBER, INCLUDING SITE ADMINISTRATORS, RESPONSIBLE FOR YOUR OWN ACTIONS AND ANY PERSONAL INJURY OR PROPERTY DAMAGE THAT MAY RESULT.
Gregor Scott, shonalex, Oderus420 And 10 others like this post
