TheBatteries
Administrator
- Joined
- Oct 8, 2016
- Messages
- 2,127
Data References:
http://www.houseofbatteries.com/documents/UR18650H.pdf
Pictures:
Brand: | Sanyo |
Model: | UR18650H |
Capacity: | 1900mAh Rated |
Voltage: | 3.70V Nominal |
Charging: | 4.20V Maximum 1900mA Standard --- mA Maximum |
Discharging: | 2.50V Cutoff 330mA Standard --- mA Maximum |
Description: | Red Cell Wrapper Black Insulator Ring 18650 Form Factor |
Data References:
Pictures:
