MPP SOLAR MPI hybrid inverter no connexion
Hello,
I received 2 days ago my MPP SOLAR MPI Hybrid inverter.
It's working well from the keyboard, and I can changes settings.
But I can not control it with the software provided by MPP SOLAR.My laptop (DELL inspiron is under window 10) The link with the inverter is USB, the inverter is not recognized. when I connect the USB cable, I can hear the sound of notification from window but nothing appears in the device management
I uninstalled the usb driver and then installed it again, but nothing.
there is an autorun on the CD, but it does not work. I copied the directory directly to my PC and executed the program with solarpower.exe. The program executes well but no communication with the inverter. The program is the same as for PIP, plus a section for grid management
Does anybody can help me ?
Hydroélectric 800W PELTON Générator - 6 x 270W solar Panel
Oct 2017 : 850 cells collected : Test in progress
Is there a usb hub or so in between the inverter and computer?  They can be a problem.
If not, try a other (short) usb cable...
(12-17-2017, 10:19 AM)wim Wrote: Is there a usb hub or so in between the inverter and computer?  They can be a problem.
No Hub, the usb cable is straight from laptop to inverter. It's a new one provided with the inverter
Still, if windows is not registrating a new usb device, it looks like a problem with the cable... or ofcourse a problem with the inverter.
Those cables provided with the inverter are cheap ones, try an other...
You can also look on the MPP website for the latest drivers and sofware, and install them, these are often newer.
I can try with a new usb cable, but one side  is a square connector, and where I live it's not easy to find. There is serie connexion on inverter what can also run the software, but no serie (db9) connector on my laptop
Those cables are pretty common, but it is Sunday in France also, i presume... Wink
A RS232 to USB converter cable is a option also, but i would try something else before, becourse those converters do not work Always.
You will not find any db9 connectors on a laptop anymore...
So the only thing you can try right now, is to download the new software and drivers from the MPP website and do a new install.
I had a look in MPP website, but I can't find any update. I have also tryed an "online update " from software but the server said I have the last one.
(12-17-2017, 10:24 AM)cristof Wrote: No Hub, the usb cable is straight from laptop to inverter. It's a new one provided with the inverter
First un-install all the old sofware and drivers, and do a proper install from the website... , this becourse in your OP you did say you only run the solarpower.exe, this is not a install, i think this could be an issue.
As i sayd, it is Sunday, so what else to do. Big Grin
Beware of that the software for the Hybrid is NOT same as the one for the PIP. The PIP uses Watchpower meanwhile the Hybrid uses Solarpower. They may look the same but they work differently and only work with said inverter.
What version of Solar power? Also have you talked to MPP about it? There was another guy that had same issue and he got another version that worked.
You got 2 different solar power versions here: https://voltaconsolar.com/monitoring-software
WuggyBuggy likes this post
(12-17-2017, 01:35 PM)daromer Wrote: Beware of that the software for the Hybrid is NOT same as the one for the PIP. The PIP uses Watchpower meanwhile the Hybrid uses Solarpower. They may look the same but they work differently and only work with said inverter.
Hi Daromer,
I use SolarPower V1.12 (the one in the CD from MPP).
I have send a mesage to MPP but it's week-end.
I'm gona test with voltaconsolar.
regards
(12-17-2017, 10:31 AM)wim Wrote: Still, if windows is not registrating a new usb device, it looks like a problem with the cable... or ofcourse a problem with the inverter.
Daromer, what is the version you use with your 3 phase 10KW MPI inverter ?
