XFX RX580 4GB Elpida Modded Bios 29.8MH/s
TheBatteries
Administrator
I'm posting a copy of my modified bios for the XFX RX580 4GB Elpida graphics card. The only updates done to this BIOS were the memory straps. I'm using it to mine ETC and am getting hash rates of 29.7MH/s. The clocks need to be set in the Claymore command line (or similar utility).
Card: XFX RX580 4GB Elpida
GPU Clock: 1100MHz
Memory Clock: 2055MHz
ETC Mine Rate: 29.8MH/s
Use at your own risk and always back up your stock bios first! ;-)
  • XFX.RX580.4GB.Elpida.mod.rom
that's crazy fast for that memory type
GPU Clock: 1100MHz
What command do I use to arrow the speeds in claymore?
Could you help me, please?
Please post your comments outside the quote bubble. Makes it hard to tell when their text ends, and your begins.
From my understanding, you use a ROM flashing tool. Do a search for Radeon Mod BIOS on youtube and you'll get loads of helpful videos.
sorry for my bad English
I already put the bios in the VGA, but I want to know which command I put to set the speed in claymore
GPU Clock: 1100MHz
i did this mod on my card, i do Ether and run on claymore and it shows me 17.3 mh/s
maybe im doing something wrong or need to adjust something else?
